![]() | Home > Technical > Vehicle rolls in Park. |
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 ![]() ![]() ![]() |
While stopping for a second the other day I noticed that if the transmission is set to 'Park' then it fails to stop the car rolling if on a very slight incline. The movement is accompanied by a sort of clicking noise that sounds, and probably is, some sort of pawl failing to engage in a cog. In all other respects the vehicle seems to work OK. (Apart from occasionally losing power on roundabouts - but I'm 99.9% sure this is a separate issue)
I think your diagnosed exactly the issue. |
That's very helpful. Thanks! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
There is a TSB for this.
Thanks - Is there a link to the TSB or some way of viewing it? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5119 ![]() ![]() ![]() |
There is this one but refers to very early cars.
Hmmm - Sounds like the TSB may not be applicable. Bizarrely, the problem seems to have corrected itself the last time I tested it. I'll see how it goes before I get the garage to dismantle the entire gearbox! |
