Home > Faults & Fixes > Injector leak |
Is it the injector spill/leak off pipe? The seals fail causing leaks.
Fri May 13 2016 2:18pm |
Lee69 Member Since: 15 Sep 2015 Location: Liverpool Posts: 24 |
I haven't got up close yet as I will have to take out battery and bits and stuff to see.
Fri May 13 2016 2:21pm |
Fri May 13 2016 2:25pm |
Thanks mate |
Fri May 13 2016 2:34pm |
Just one thing .! On the picture where the blue gloves are holding a connector with a split o ring on it , is that the injector itself or is that another part to it.
Fri May 13 2016 2:55pm |
[quote="Bodsy"]
Fri May 13 2016 3:07pm |
That's the leak off part connected to the injector. There's a small metal clip that holds it in place on the injector that sometimes comes out.
Fri May 13 2016 6:58pm |
Fri May 13 2016 7:12pm |
Fri May 13 2016 7:15pm |
Hi guys just an update on the leak problem.
Tue May 17 2016 5:55am |
Clip only available as an expensive injector fitting kit from LR or available for £2.93 here....
Tue May 17 2016 8:39am |
Thanks for the help
Tue May 17 2016 9:10am |
Having trouble trying to obtain the o-rings it says nothing matches your search item number. |
Tue May 17 2016 9:41am |
I would just like to say a BIG thank you to Bodsy for your continued support and contribution to this site. Going out of your way to help this guy. It's people like you with your knowledge and experience, that makes this site what it is today. Fantastic. |
Tue May 17 2016 9:54am |
