Home > Technical > External air temperature
Jaggs
Last couple of days I have got in the RRS after work and it's showing 8 degrees when it's clearly late teens if not 20 plus outside, after a 3 mile journey it's raised to 13 degrees, is this right to build up to external temp or should it show on start up.
I've located the sensor but can't get the wired plug off or remove the sensor from its mount depite pulling , squeezing and lifting tabs it's not moving.
So is it faulty and how do you remove it if it is ? No skin on my knuckles now Crying or Very sad Nanocom Evo
Post #495413 Sun May 08 2016 6:10pm
I posted a similar problem which I'm blaming on the computer software.
I bet it was 8 Deg when you switched the car off in the morning ?
Post #495422 Sun May 08 2016 7:33pm
Jaggs
I would imagine it was as it was 7am when I parked up, I don't recall it doing the same thing last year did you resolve yours Nanocom Evo
Post #495445 Mon May 09 2016 8:03am
Camelrock
Had a similar thing happen the other week was about 1 when I got to work, went out to the car dinner time when it was late teens and still said 1 in fact when I started the car the FBH fired up.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #495449 Mon May 09 2016 9:11am
Jaggs
Did it resolve its self Camelrock or still ongoing ? Nanocom Evo
Post #495456 Mon May 09 2016 10:19am
Camelrock
Sorted itself out and back to normal, not done it since. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #495458 Mon May 09 2016 10:22am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
My 07 did the same thing a couple of times and then sorted itself out, I would sit tight and see if the problem goes away..
Post #495462 Mon May 09 2016 10:59am
Jaggs
After a few days of slow readings it's settled back down to normal, got to love the gremlins in these vehicles, looking forward to the next surprise. Nanocom Evo
Post #495542 Tue May 10 2016 9:05am
Camelrock
It would be pretty boring if they didn't give us something to worry about, I could do with some boredom for awhile Confused 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #495560 Tue May 10 2016 12:29pm
Evolution
Spain 2006 Range Rover Sport Supercharged Santorini Black
Hello
Where is the external temperature sensor? Thanks
Post #533857 Sat Aug 26 2017 12:10pm
behind the bumper I think
Post #533878 Sat Aug 26 2017 9:14pm
Bobby
Its in the front of the engine compartment - Centre
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #533931 Mon Aug 28 2017 12:51am
Prykey
Is the external temperature sensor located in this position on a 2011 RRS with the 3.0 TDV6 engine?
Post #552585 Thu Mar 29 2018 7:51am
Meiang
"Is the external temperature sensor located in this position on a 2011 RRS with the 3.0 TDV6 engine?"
It isnt on my 2010 TDV8.
Post #552782 Sat Mar 31 2018 10:01am
Bobby
On the 2011 models, the sensor is attached to a bracket on the rear of the bumper beam, on the vehicle center-line. Malaysia Boleh!
Post #552855 Sun Apr 01 2018 12:48am
