Home > General > Fitting a new DRM module on TDV8
harryp
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Has anyone had experience replacing the Dynamic Response Control Module on a TDV8 (part no NNW508200)?
I understand this is located somewhere behind dash on driver's side, but have no idea how to get to it or what is involved.
Any help much appreicated as have been quoted £650 for the job by an indy garage and see part can be had for circa £200.
Many thanks
Ian
Post #495295 Fri May 06 2016 9:54pm
I could be wrong here but I thought it was on the passengers side behind the kick panel by the lower glove box.
Apparently it's always on the Drivers Side, must have been looking at a LHD. Embarassed
Post #495299 Fri May 06 2016 10:21pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
How do you propose programming it to talk to the car?
I don't think it is just a case of unplug old, plug in new... May be wrong! 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #495300 Fri May 06 2016 10:22pm
The module is on the driver's A pillar behind the instrument panel. Access it through the foot well by removing the two panels. One pulls off, the other has a couple of screws and a clip from memory. Move the seat fully rearwards to help access. You can see the module by getting your head down in the pedals. Note: the air suspension module lives in the same location. The air suspension module has 4 connectors, the DRM only 2 connectors.
The module has two tunes (maps) on it - one for the TDV6 / petrol engines and one for the TDV8. I think this is because of the weight of the TDV8 engine compared to the other two. You need to select the correct tune in the config file. 2012 SDV6 - it's missing a couple of cylinders
Post #495318 Sat May 07 2016 11:44am
harryp
Many thanks RRSTDV8. Sorry to trouble you further, but how easy is it to do the setting once installed? Do I need any special equipment?
Post #495335 Sat May 07 2016 3:52pm
Not sure whether something like an IID Tool would set it up or whether you need a Land Rover box to do it. 2012 SDV6 - it's missing a couple of cylinders
Post #495339 Sat May 07 2016 5:54pm
