Home > Maintenance & Modifications > Replacing the alternator
Grahamjthrower
Hi guys I said to my wife's aunt and uncle I would change the alternator on the Range Rover hse sport v6 diesel.
I've got the two of the three bolts out. The one at the top the one to the underside rear and the front underside is loose.
To get the alternators last bolt out and to remove the alternator I think I have to take the active roll pump out. Or remove it from the mountings with out remove any pipes or lines.
Is the any kind soles out there that can shed any light and help me with this situation. It's turning out to be a real pig of a job.
Thanks Graham
Post #492300 Thu Mar 31 2016 12:34pm
gogsy1956
Have a look here http://api.viglink.com/api/click?format=go...82516.html 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #492327 Thu Mar 31 2016 5:36pm
Disco_Mikey
Unbolt the ARC pump, and push it down and back Thumbs Up
Post #492331 Thu Mar 31 2016 5:57pm
Grahamjthrower
Hi thanks for the reply. How many bolts hold it on and where abouts are they.
Post #492337 Thu Mar 31 2016 6:31pm
Disco_Mikey
3x bolts, all 10mm
Can't remember where they are though Embarassed
Post #492347 Thu Mar 31 2016 7:24pm
Grahamjthrower
Ok thanks. Will let you know how I get on. Appreciate your advice.
Post #492348 Thu Mar 31 2016 7:31pm
