![]() | Home > Wheels & Tyres > What replacement tyres? |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
Depending on what you go for would recommend going from 40 profile to 45 improves comfort and increased alloy protection with the slightly thicker sidewall fills the wheel arch better as well. Personally running general grabber at2's but you might want something more road bias.. 2008 G4 RRSport TDV8 current
steve99 Member Since: 12 Sep 2015 Location: London Posts: 30 ![]() ![]() ![]() |
Liking the 40 to 45 recommendation as 6'6" width restrictions have left a mark on my rims! |
http://www.rrsport.co.uk/forum/topic39605.html
ozzievechi Member Since: 14 Mar 2016 Location: london Posts: 55 ![]() ![]() |
just ordered 4x 275/45/20 Michelin sport latitude 3 for 166 a corner on mytyres.... dunno if its mispriced as on blackcircles and all overs they are about 200-214 a corner...get in quick |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5097 ![]() ![]() ![]() |
Depends on whether you ordered "V" or "Y" rated, for some strange reason the "Y" rated tyres are cheaper than the "V" although they are a Higher Speed Rating 186mph for the "Y" as opposed to 149mph for the "V".
good spot..... does anyone know if the composition of the tyre is different? 186mph for the Y, 149 for the V
Could simply be based on the popularity of the particular rated tyre. Rightly or wrongly I simply work on the basis that the higher rating would be the better tyre .
Sports need a Y I was led to believe as that is what factory fit. Any change needs insurance notifying |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9092 ![]() ![]() ![]() |
Load rating is more important than speed rating. Speed rating is simply the maximum speed the tyre will handle when running at maximum load. Run it at less than maximum load and it would run to a higher speed. You are required to run the tyre at a suitable pressure for the load applied according to the Highway Code.
So as I understand, so long as the load is 106 or above its OK?
Speed Symbol "U" For vehicles with a speed capability not exceeding 200 Km/h (125 Mph)
Well in the end I decided to get the puncture repaired and stick with what I had for a few months. Whilst they were taking off the rear to fix it the eagle eyed tyre shop owner spotted a bulge in the sidewall on the offside front. It is there but small but definitely needs a new tyre. He wouldn't match Blackcircles price even though he is one of their approved fitters (£20 more per corner). He gave me some BS about how BC waiting times might be days but I knew I could arrange with 2 days.
New on back, old on front |
