Home > Technical > engine management light on permanant
normark
England 2009 Range Rover Sport TDV6 HSE Santorini Black
hi everyone Ive had my engine management light come on 60 miles from home the book says ok to drive unless it starts flashing which it did not so i got home but puzzled what it could be its very sluggish but i floored it just to try it really and it did kick in and i could have kept a good speed but didnt want to risk it too much but then all junctions really sluggish. Its a RRS 2.7 HSE 2009. only just had a compressor and 75000 main service done
Iknow it will probably need another diagnostic but can anyone give me a ideas of what the cause could be
many thanks
Post #491389 Sun Mar 20 2016 8:34pm
Disco_Mikey
EGR issue Thumbs Up
Post #491394 Sun Mar 20 2016 9:07pm
Bodsy
Site Sponsor
Mist likely EGR as Mike says. Thumbs Up
I can blank them out and update the software if that's of any interest? Means you never need to replace either of the egrs in the future. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #491396 Sun Mar 20 2016 9:18pm
normark
Thanks Disco Micky and Bodsy
Bodsy what does it involve blanking off. What is being blanked off ? sounds great mate if it can be done but do you think it will solve the problem
do you think I should shell out for a diagnostic first ?
really sorry mate but I know nothing about moters
Post #491406 Sun Mar 20 2016 11:31pm
Bodsy
Site Sponsor
It's the most likely cause of the problem you are facing.
The Blanks go between the EGR valve and the pipe that goes to the air intake. There are two egrs and they both need to be blanked and the centre butterfly valve removed.
Then a software update to stop the engine management light coming on.
That can be done as a stand alone software update or as an add on to an engine remap if you wanted to take the opportunity for that at the same time.
I'll drop you a message.
Regards
Ian Bodsys Brake Bible
See it HERE
Post #491421 Mon Mar 21 2016 8:56am
DrRob
Ian - if you come down to Hampshire for this then give me a shout and you can take a look at my EPB shoes - adjust properly etc.
Rob Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #491441 Mon Mar 21 2016 11:38am
normark
Regards
Ian
hi mate sounds good lets arrange it to be done, ive sent email but not sure if you will recieve it from my old lap top
regards Dave
Post #491460 Mon Mar 21 2016 3:04pm
