![]() | Home > Maintenance & Modifications > Range Rover sport wobbling 2006 |
Are the large harmonic damper weights that are (should be!)slung under the rear of the car and are free to slide still there? There was spell when people were moving them because they didn't understand what they were for and they are incredibly heavy, but they are there to counter pitch and nose dive under heavy braking. Another thing that can cause a wheel wobbling effect is if the car has been offloaded in a lot of deep mud and the mud has been allowed to dry out ion lumps on the insides of the alloys where they act like invisible (until you remove the wheel) balance weights that will put the wheel out of balance. In the very early days of RRS there were a huge number of complaints about accelerated tyre wear and wobbly wheels and it was found that although the wheels had been supplied with balance weights these had fallen off before the car ran off the end of the production line............ Check that your wheel balance weights have not been jet washed off. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 ![]() ![]() |
Hi mate cheers the balancers are fine. I honestly don't think it's a wheel balance issue.. Defo not mud as my wife only uses it as a bus. It's doing my head in tho. Could sideways movement of the wheels cause it? Ie the bushes?
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
If your talking about your anti roll bushes then normally if they have worn you will hear clonking noises when you go over bumpy roads.
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2022 ![]() ![]() |
You have Flack nr you (Preston) who is a rated mobile mechanic in the NW on Disco3 forum
No not the roll bushes, the upper Susp at bushes. |
I'll try grab flack, see what he can do🍺🍺 |
