Home > Technical > Fan Removal
Fan Removal
Any tips on removing the engine fan ?
Damm thing is on there tight !
Post #488277 Sat Feb 20 2016 6:45pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Probably a left hand thread! 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #488288 Sat Feb 20 2016 8:49pm
Yes. I thought it was.
Post #488294 Sat Feb 20 2016 9:02pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Put the wrench on the nut (yes left hand thread) - and use a pry bar (or special fan tool) to stop the pulley spinning - sharp blow with a rubber mallet to the wrench on the nut normally works best. I just did it on my bmw and there are various you tube videos out there showing you how to do this ...
Post #488472 Mon Feb 22 2016 4:29am
Jylee
United States 2007 Range Rover Sport 4.4 V8 HSE Orkney Grey
Al is right, you need a fan clutch hold-on wrench, and a correct size wrench. I needed a 1 1/2" wrench to remove the fan nut to change the water pump on my Dodge last week. I tried varies tools from pipe wrench to regular adjustment wrench did not work. Many trips to the store, until I found a large adjustable wrench. The nut was off in 2 minutes. I also suggest to ask a helper to hold to one wrench, while you swing a hammer on the the other wrench.
Post #488579 Mon Feb 22 2016 10:58pm
I got it off yesterday thank you.
I needed to hit it with a hammer.
Post #488580 Mon Feb 22 2016 11:03pm
