Home > Technical > Heated Windscreen not working
chi
I recently had a problem with the relay for my heater motor. Lost for Words very kindly advised me to check the relay , which indeed was the problem.
Over the last few years my heated windscreen has had some of the elements not working, however it still did partially work. Now it has stopped working altogether. I have checked the two engine compartment fuses no,s 15 and 18, all okay. I have also changed the relay. I now want to check with a multimeter that i have 12 volts at the windscreen connections under the A pillars. Is it okay to remove the A pillar trim without disturbing the Air Bags beneath?
Is there any other fuses or relays that i have missed that need checking?
Thanks for any guidance you can give
Keith
CHI
Post #488101 Fri Feb 19 2016 4:16pm
Terryrrs
I expect it was that large stone that hit your screen and broke it Shocked
Post #488114 Fri Feb 19 2016 5:52pm
chi
OH , That was it: Very Happy
Post #488488 Mon Feb 22 2016 11:52am
Re: Heated Windscreen not working
Keith
CHI
Yes no problems with Airbag's. Not totally sure about stone hitting screen being responsible as Heater Element is actually in two halves a R/H Off Side and L/H Near Side hence why you have two fuses under bonnet. Would have thought it unlikely stone could damage both elements at same time but is always possible I suppose.
Post #488537 Mon Feb 22 2016 8:25pm
