Home > Technical > Vibration through steering wheel and car on Acceleration
Garage Door Medic
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
As above, driving normally no problems at all, but when driving 65 mph on the motorway and I put my foot down to pull away, the steering wheel vibrates and so does the car. As soon as I take my foot off it stops, I can drive 80 mph no problems, smooth as normal. Just had my wheels balanced and it's made no difference. Driving it fast from a start doesn't create this, just at higher speed. It goes out of Warranty in May, I have 21000 on the clock. Is it a trip to the dealers ???
Thanks for reading MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Ivory Premium Leather
Side steps
Disklok !!!!!!!
Mud Flaps
Spare wheel protector
Post #487933 Thu Feb 18 2016 6:18pm
Jylee
United States 2007 Range Rover Sport 4.4 V8 HSE Orkney Grey
Warped front rotors.
Post #487938 Thu Feb 18 2016 6:48pm
Garage Door Medic
Thanks Jaylee, forgive my lack of knowledge what's a rotor ??? MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #487941 Thu Feb 18 2016 7:02pm
Lost for Words
The favoured term for brake discs across the pond. Wink
Check the temperature of your wheels for sticking calipers/EPB shoes. Thumbs Up Visiting from DISCO3.CO.UK
Post #487943 Thu Feb 18 2016 7:07pm
Garage Door Medic
Thank you will take it for another spin and see if there is any heat. The garage did service my EPB a couple of months ago. Thank you MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #487945 Thu Feb 18 2016 7:18pm
SH0X
Check your wheel balancing
most cars wobble at a certain speed level if they require wheel balancing - about £5-£10 a wheel you should try starting with fronts only
Start with the basics IMO
another one to check when the wheels are off is the brake disc retaining bolt(s)- I had plenty of mechanics tell me that these bolts were not important and for manufacturing ease only - from my personal experience I can tell you that is a load of lies & they do have a huge purpose in the whole braking system / vibrations
Post #488325 Sun Feb 21 2016 1:07am
Garage Door Medic
Thanks, bit had all wheels balanced 1st and still as bad, booked it in at the dealers, they want £95 to inspect it and should it be warranty no charge. Will see what they say, can't see it can be anything worn with only 20 k on the clock and I've never ragged it MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #488335 Sun Feb 21 2016 3:14am
SH0X
Maybe somethings come out of line or touching something else from a pot hole or bump it's real hard to pin point without a inspection as they suggest and sometimes a road test and further investigation to provoke to problem to pin point.
Best of luck. .. luckily you have warranty
Post #488596 Tue Feb 23 2016 3:09am
DrRob
Is it still under warranty? If yes, call LR Assist. Its free so nothing to lose Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #488607 Tue Feb 23 2016 8:29am
drdelrrs
If its vibrating under load (acceleration) I'd check all the drive shaft and prop shaft joints; especially the centre mounting.
Post #488621 Tue Feb 23 2016 10:36am
Garage Door Medic
Dropped it off Tuesday, they phoned me Wednesday at 5.pm saying they have driven it and can feel the fault, but they have no idea what it could be, they did mention that my tyres have been known to hold water, and could they keep it so they can work on it today. I was expecting some call to give me info on what they have or haven't found, but they have not, so I am still no wiser. MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #488957 Thu Feb 25 2016 10:26pm
Garage Door Medic
Water in the Pirelli 20" tyres is the cause of this problem. I asked how often I will need to "empty my tyres" Laughing Laughing Laughing
They said Pirelli have an update and a sealant around the rim, so hopefully this is the end of it. MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #489062 Fri Feb 26 2016 6:51pm
Mr Rusty
Scotland 2013 Range Rover Sport SDV6 Autobiography Fuji White
Glad you got this sorted! Weird! Thumbs Up 2015 RRS AB SDV6, Fuji White, Ivory
2012 RRS HSE SDV6, Sumatra Black and Ivory
Audi A5, 3.0 TDI, Gone
Audi TT, 3.2 V6, Gone
BMW 5 series tourer, Gone
Post #489073 Fri Feb 26 2016 9:07pm
Garage Door Medic
I was expecting the £95 charge, but they did it all through warranty. Well done Farnells of Bury. MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #489224 Sat Feb 27 2016 10:07pm
