![]() | Home > General > 2011 RRS diesel battery replacement |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5123 ![]() ![]() ![]() |
I intended to fit a 019 battery when I replaced mine as various catalogue's state this is a option, however it is some 40 odd mm longer than the original and really could not figure out how to get it to fit properly without bodging it in, so decided to fit the correct one which is a G14 AGM one or equivalent I think.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4518 ![]() ![]() ![]() |
The correct battery is an 017
Pauljc84 Member Since: 16 Feb 2016 Location: Scotland Posts: 3 ![]() |
Looking at euros I think he maybe got the 020 s5 battery as it is huge!
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9119 ![]() ![]() ![]() |
Yuasa 019 fits in pre-facelift RRS although I needed to fiddle to get it in. 2012 SDV6 - it's missing a couple of cylinders
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
I thought all the 017s and 019s are, in practice, the same size? 353x175x190. Visiting from DISCO3.CO.UK
I think they are, however the Yuasa unit I put in recently has a slightly different lip shape/size along the bottom edge. The battery box appears to be designed to hook over this bottom lip, presumably to help hold it in place. I just needed to remove a little bit in the battery box to get it to fit. The rest of the lip sits as originally designed. 2012 SDV6 - it's missing a couple of cylinders
Yeah I just checked the battery spec and it says 353/190/175 so should be ok. It is the base which is too fat and can not slip under the trays lip. This then means the bracket bolt is hidden on the passenger side.
Yeah I think I got it wrong it was a 020 which I was told would fit, but it wouldn't as it was 393mm long and you just could not get it in the space.
Exactly what I found with Yuasa too. Managed to fiddle it so that it fitted OK in the end. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
I have a Yuasa HSB019 in my 2011MY. I don't know how easy or hard it was to fit because I procured the services of a small boy (at Halfords). Over a year on and no issues to report! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Have you checked that it is actually secured correctly? On mine the only way to get the clamp bolts in was to mod the lip at the bottom of the battery box. Easy enough to do so perhaps your small boy did that too. 2012 SDV6 - it's missing a couple of cylinders
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 ![]() ![]() ![]() |
We recently had a YUASA 9019 AGM Battery fitted.
