Home > In Car Electronics > Interior lights
Yetiman
2006 Range Rover Sport TDV6 HSE Stornoway Grey
Interior lights
Hi all, I have a minor irritating problem. The rear interior lights don't come on when the doors are opened but can be switched manually. I'm sure I've read that the system can be re set, is this correct ?
Jez
Post #486460 Wed Feb 03 2016 2:20pm
No they cannot be reset, but I believe the is a Modification you can do to the wiring to enable this.
Post #486462 Wed Feb 03 2016 2:27pm
See here... Thumbs Up
http://www.rrsport.co.uk/forum/topic20566.html
Post #486464 Wed Feb 03 2016 2:51pm
Yetiman
Thanks for the replies. I find it very odd that they make the car with no automatic rear lights.
Post #486513 Wed Feb 03 2016 10:10pm
You and ever other RRS owner. Whistle
Post #486515 Wed Feb 03 2016 10:34pm
Socast
or triple flash indicators, or folding mirrors, or one touch windows all round, or side/headlight dash alert, or aux port on the dash, or Bluetooth audio streaming, or a dash clock, or.......... Rolling with laughter
Post #487247 Fri Feb 12 2016 12:24pm
Lost for Words
Yep, but 3-flash indicators and the clock on the dash can be enabled and, to a degree, so can the sidelight tell tale. Thumbs Up Visiting from DISCO3.CO.UK
Post #487248 Fri Feb 12 2016 12:27pm
Socast
True they can be enabled, but why aren't they a standard feature !?
Also the disco and full fat have an actual clock on the dash, the side light alert would be better if it was an actual alert rather than a repurposed one.
Post #487250 Fri Feb 12 2016 12:32pm
Lost for Words
Well at least they did become standard in 2007. As far as bluetooth streaming goes, it's easy to look at with hindsight, but I suppose that just wasn't so big back then. I'd take the old fashioned simple interface with buttons over a touchscreen controlled network of connections any day! Thumbs Up Visiting from DISCO3.CO.UK
Post #487255 Fri Feb 12 2016 12:44pm
Yetiman
Oh yeah, the aux port in the back is a bit stupid, a couple of times the kids have pulled the plug out accidently in the dark. I'm slowly getting used to finding the clock now. I'm surprised with the lack of thought, they didn't put the clock in the boot !! Laughing
Post #487377 Sat Feb 13 2016 7:31pm
TheWojtek
Someone should build and sell a wiring kit for rear reading lamp conversion. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #487378 Sat Feb 13 2016 7:35pm
Bodsy
Site Sponsor
I can add the clock on the dash for you Yetiman. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #487379 Sat Feb 13 2016 7:36pm
