Home > In Car Electronics > Steering wheel conrols malfunctions
C C
United Kingdom 2011 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
2011 MY
I have recently experienced some odd things happening with the steering wheel controls. For instance. The voice command button when pressed will call my phone out to the last number called, the end call button dose nothing at all. Also the stereo controls go wrong. Pressing volume up will change the audio mode. Next track and pervious track will replay the same track. When this is happening I dear not use the cruse control. Usually the next time I drive the car everything is back to normal then after a while it goes wrong again.
Any ideas what is going on and how to prevent it.
Post #485915 Thu Jan 28 2016 2:32am
scarey
disconnect the battery for about an hour, this should reboot the ecu..
Post #485919 Thu Jan 28 2016 9:02am
Hi
Could be issue with the wiring harness inside the steering wheel, I think there are a few post's on here with similar issues not overly expensive and quite easy to change. You do need to remove airbag to replace it though.
Not certain that is your problem just a suggestion.
Post #485920 Thu Jan 28 2016 10:01am
Lost for Words
Sounds like the clockspring but worth checking the above first. Thumbs Up Visiting from DISCO3.CO.UK
Post #485927 Thu Jan 28 2016 11:09am
C C
Thanks for the insight guys. At least I have a starting point.
Post #485957 Thu Jan 28 2016 7:02pm
Jason kenya
Kenya 2006 Range Rover Sport Supercharged Orkney Grey
Hi C C, did you figure out what is causing this?
I have the same problem, intermittently. Volume up changes mode, volume down gives me voice command.
Strangely, cruise control seems unaffected apart from the distance control for the ACC, pressing the button has no effect.
It's only occasional and seems to be after I've parked in the sun for a little while.
Perhaps the heat is causin the steering wheel to warp a little?
Post #485976 Fri Jan 29 2016 12:45am
C C
The car is still under warranty from the dealer I bought it from Jason. So I will talk to them first then get it looked at locally.
It did it again today. Was Ok at first but after a while things went out again.
I'll update the forum of the outcome.
Post #485978 Fri Jan 29 2016 1:16am
C C
Post #485979 Fri Jan 29 2016 1:17am
C C
After two trips to my local Indi they could not find any fault. However they carried out a software update to the 'Infotanmant Module'. Two days on and the problem has not manifested it's self. So perhaps that has cured to issue.
Timme will tell.
Post #487966 Thu Feb 18 2016 8:29pm
C C
I replied too soon. The controls have returned back to being unpredictable. One moment working correctly. The next pressing the increase volume will make to audio change from radio to CD or USB player. Hitting the voice control tab will make the phone call someone.
Then within a sort while it will behave normally again.
Post #491734 Fri Mar 25 2016 7:02pm
Disco_Mikey
Sounds very like a faulty wiring loom behind the airbag Whistle
Post #491746 Fri Mar 25 2016 9:23pm
C C
You could be right Mikey. I have suspicions myself. However the guys at my local Indi said it checked out ok. Certainly no faults reported so I could not get it fixed under the warranty. Sad
I'll live with it for now. Then get it looked at again at MOT time or when something breaks (which ever happens soonest Confused .
Post #491751 Fri Mar 25 2016 10:10pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Morning all.
I have exactly the same intermittent steering wheel audio control issues on my 2012 SDV6, has anyone had a this problem resolved ?
Thanks in advance for any replies...
Post #505577 Fri Sep 16 2016 9:28am
C C
Apologies for not updating the thread. Directly after having the audio software updated I noticed no difference. However after a few weeks the problem has gone away and everything is working as it should.
Make of that what you will. But its probably worth getting the layered update installed anyway.
Post #505585 Fri Sep 16 2016 10:30am
1JBS
Many thanks for the update, just spoke to my Land Rover main dealer and apparently diagnostics and wiring are not covered by the warranty Rolling Eyes so looks like a trip to my independant guy for an update. Thumbs Up
Post #505592 Fri Sep 16 2016 12:20pm
