Home > For Sale & Wanted > [For Sale] 2010-2013 Reversing Camera
2010 - 2013 Reversing Cameras.
One Brand New, One Used.
These are the Fixed Reversing Camera only, they are Not the Surround Reversing Camera. The Normal Camera has a Fakra Connector with Two terminal Pins the Surround Camera has Four Pins.
New One £70.00 inc. Delivery
Used One £40.00 inc. Delivery
Not wishing to offend anybody but if you buy these please do not contact me telling me they do not work or cure your problem, as in the past I have had people asking for refunds and returning different part's to those sent, or simply just trying them to see if it cures their issue. Not on this Forum though I hasten to add.
My apologies if that offends anybody but if you will not accept "sold as seen" please do not buy.
Post #484389 Sat Jan 09 2016 9:10pm
andywatson
Hi Col,
Do These just plug and play or would I need additional equipment, cables?
I have a 59 plate, 2010 MY RRS, would be happy with the used camera 2008 RRS 3.6 HST - Stornaway / Black - Current
2010 RRS 3.0 HSE - Nara Bronze / Almond - Gone
2009 RRS 3.0 SE - Sliver / Teal
Post #484392 Sat Jan 09 2016 9:56pm
If you already have a camera already fitted it would simply be a straight swap. There were two different Rear spoilers fitted one with the aperture for camera and one without. If the car came without a camera fitted you will have the blank one, the position is there however you would need to drill a suitable hole for the camera lens in that position, in addition there is a small separate mounting bracket you would need that the camera fit's in then clips into the spoiler to hold the camera in place.
The main problem is if a camera was not fitted from new I wouldn't know if the Wiring is there or not, one option would be to remove the Spoiler and check or you may be able to just pull out the rubber wiring conduit to the spoiler and see if there is co-ax cable running to the spoiler if so then I think the wiring would be there.
I see you have a SE if you have a word with Mark (Aka) ABSport he converted a SE to a Autobiography including Rear Spoiler, I may be being presumptuous but I'm sure he will help you if he can
Post #484393 Sat Jan 09 2016 10:21pm
andywatson
Thanks Col, no camera fitted from factory so will have to check for a cable. 2008 RRS 3.6 HST - Stornaway / Black - Current
Post #484394 Sat Jan 09 2016 10:26pm
Col wrote:
I see you have a SE if you have a word with Mark (Aka) ABSport he converted a SE to a Autobiography including Rear Spoiler, I may be being presumptuous but I'm sure he will help you if he can.
Post #484395 Sat Jan 09 2016 10:32pm
Tommy83
Hi Col,
I would like a new one of these please, I see you are in Abingdon, can I collect with cash?
Post #484481 Mon Jan 11 2016 11:12am
Bodsy
Site Sponsor
They are an absolute steal at that price!
Fitted some d4 LR cameras recently and the camera on its own is £200!! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #484487 Mon Jan 11 2016 12:05pm
Tommy83 wrote:
Hi Col,
Hi
Have sent you a PM not sure if can actually receive them yet as you only have a few post's, but the camera is yours if you want it.
Post #484488 Mon Jan 11 2016 12:42pm
Tommy83
Hi Col,
Fitted the camera today, works perfectly.
Thanks very much!
Tom
Post #484778 Thu Jan 14 2016 11:52pm
Hi Tom
Excellent Thumbs Up
Post #484782 Fri Jan 15 2016 12:08am
