Home > Wheels & Tyres > 2015 21 inch alloys
Hobbsy121
2015 21 inch alloys
Does anyone know whether 2015 21 inch alloys fit on my 57 plate rrs ? Thanks
Post #484300 Fri Jan 08 2016 7:50pm
jasons
2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Yep but check the tyre height as it will put the speedo out (larger rolling diameter or something like that...)
I have 21s on mine from a 2015 model.
They fill the arches nicely though! 2012 RRS HSE. Firenze Red.
Post #484304 Fri Jan 08 2016 8:29pm
Hobbsy121
Ok so do you think the wheels may need a lower profile than a 45 ? Thanks mate
Post #484307 Fri Jan 08 2016 8:47pm
Have 21" with 45 profile, At 30mph speedo reads between 31/32 mph, at 50mph reads 52/53 and a 70mph reads 74/75 mph that's compared to GPS Signal. So no major variation, simple answer just drive a couple of mph slower based on speedo reading.
Post #484314 Fri Jan 08 2016 9:30pm
Xstyle
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
How much are the 21" rims?
Are they advertised on the RR site?
Post #485306 Wed Jan 20 2016 7:02pm
Try Dan at Duckworths or plenty of set's on flea-bay.
Post #485307 Wed Jan 20 2016 7:16pm
AS90
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HST Santorini Black
Does the offset give any problems, I'm looking at this one is 49 and the other 53 not sure if that bad or it's acceptable.
So any advice I would also like.
Post #486154 Sat Jan 30 2016 10:43pm
