![]() | Home > Technical > suspension fault on rrs |
normark Member Since: 17 Sep 2013 Location: hampshire Posts: 35 ![]() ![]() ![]() |
Hi all,
well thanks for all the info I hope I can be of assistance too someday |
wings21660 Member Since: 11 Feb 2015 Location: Gretna Posts: 65 ![]() ![]() ![]() |
Are you positive it is the compressor, only i had this problem but a lot cheaper fix it was under the car where a hairline crack appeared in a pump?? The fault code was C1A20/64 a guy called Gruodiz on this site has designed a great replacement for the cover on the compressor where the two black tubes go into. Look this guy up and read his fixes on here it might save you a few quid |
Thanks wings21660
Hi all
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2015 ![]() ![]() |
Take it to Mark West at West 4x4 nr Bishops Waltham...... |
Many thanks DrRob
Mark is always busy but perhaps leave it with him to look at between jobs if you have a second car you can use.... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
