![]() | Home > Maintenance & Modifications > What oil |
Morepower Member Since: 26 Aug 2014 Location: Somerset Posts: 13 ![]() ![]() ![]() |
Hi all, can I use normal power steering fluid in my RR Sport? 2007 3.6 V8 |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
A man in a shop told me the Castrol stuff is only put in because the vehicle could end up anywhere very hot or cold, and Dexron 2/3 is ok for the british climate 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
If you use dextron 11 in your PAS you'll have problems like leaking seals in the pump and rack as cold climate and dextron are not comparable. Use the correct oil the guy in the shop was talking bull **** 2008 G4 RRSport TDV8 current
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9136 ![]() ![]() ![]() |
As the cold climate oil is used in the dynamic response system there is no reason to buy anything other the correct stuff. 2012 SDV6 - it's missing a couple of cylinders
