Home > General > Removing Wing Mirror on Range Rover Stormer 2009
RRStormer
Hi Guys,
Some numpty decided to take out my passenger wing mirror, i've got a new one but i can't find ANYTHING relating to changing the mirror itself, only the glass.
With all other cars, it's been a case of popping off the triangular (tweeter) trim, then undoing 3 bolts and bobs your uncle, however the only reference to removing wing mirrors for the RR is on youtube for a Vogue where the full door panel has to be removed also.
Can anyone confirm either way?
Thanks!
Post #482187 Fri Dec 11 2015 1:09pm
I do remember having to change the O/S on my old sport 09 plate and sure you only remove the Tweeter Trim as you say and the three bolts. If I recall right you may have to just pull the corner of the door panel out slightly to get to the multi-plug connector but you do not need to remove the complete panel.
Post #482200 Fri Dec 11 2015 3:16pm
Bobby
Could this be of help..?
http://www.rrsport.co.uk/gallery/albums/us...rror~0.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #482231 Sat Dec 12 2015 12:36am
RRStormer
Thanks guys, i did have to remove the door panel (only at the top clips) as couldnt get to the mirror connector otherwise. Anyway all done and appreciate the help.
Post #482498 Tue Dec 15 2015 10:02am
Wayneclarke
did you need to undo all the screws on the door panel to pull out the top ?
Post #482522 Tue Dec 15 2015 5:34pm
