![]() | Home > Faults & Fixes > ace valve block split pipe |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4507 ![]() ![]() ![]() |
Be aware that those pipes can run in excess of 50 bar of pressure... |
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 ![]() ![]() ![]() |
thanks mikey, I will get some stainless hydraulic fitting with can withhold 1500 psi, 100 bar, I have tried to get the original pipes which fit to the manifold block, but not having much luck and not sure how they connect to the block, I can see 2x 13mm nuts which holds the flange to the valve but is this flange and the 4 pipes one unit or can you remove each pipe individually |
