![]() | Home > Maintenance & Modifications > Exhaust mod ideas please |
You don't have to call me Sir, even though others around here do |
gangnam007 Member Since: 17 May 2015 Location: london Posts: 49 ![]() ![]() ![]() |
Hi sir yes I meant svr lol
Try giving Powerspeed in Asford Kent a call. Easy trip down the M2 from London.
well i just visited john ashley exhausts in walsall yesterday and they said that doing a straight pipe might help - has anyone installed a straight pipe or x pipe on there car? |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 752 ![]() ![]() ![]() |
I have replaced the big muffler under the car with an X-pipe. The car is only marginally louder, however it takes a lot of effort in sport mode to make it crackle and bang like the SVR does. And it only happens on downshifts, since the engine ECU is not pre-programmed to momentarily overfuel on upshifts like in the SVR. Regards etc.,
so is yours a supercharged version also?
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
I'm sure the boys above who'll decate your car will make it fail an MOT unless there just going to remove the guts and leave the cans ? 2008 G4 RRSport TDV8 current
Yes, an SC. IMO to make it more SVR-like you'd have to remove the catalytic converters and all but the rear silencers and overfuel the car a bit (which means: a custom tune should be able to do the job). X-pipe instead of the center muffler frees up more of the V8 "burp". Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
ok so the sounds of things we won't be able to replicate a svr lol
I have replaced the centre section with a X-pipe and I haven't noticed the car to use any more fuel than the obscene amount it does anyway. Regards etc.,
whats the sound like with the x pipe on? have you got any videos? does yours still have the original back boxes? |
I will record you a clip. Regards etc.,
did you manage to record a clip |
Hi, I hadn't had time before and had to ask my 6-years-old to record it using the phone, lol. Anyway, here you go.
