![]() | Home > Technical > Red Warning triangle |
KennyR Member Since: 28 Jul 2015 Location: Gourock Posts: 178 ![]() ![]() |
I had a red warning triangle with exclamation mark show on my dash with a message saying pull over safely and turn engine off while I was on my way to the airport, I couldn't miss my flight, anyone have any idea what it could mean, didn't give any clues! Should I attempt to drive it when I return or call LR Assistance ? ____________________
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4516 ![]() ![]() ![]() |
Did you switch off and back on at all? It may have been a glitch, and may not be there upon your return
Hi Mikey
You will need to have it plugged into an appropriate diagnostic tool |
Cheers, I'll see what happens on return, but it's under warranty so I'll get it checked, just wasn't sure if driving it would cause an issue, no performance issues etc ____________________
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2015 ![]() ![]() |
Call them in advance and get it booked into the LRA system for them to meet you at airport or home..... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Thanks Doc.. Will do! |
Wee update, had LRA out on Monday and the Anti Roll Bar fluid was low, checked underneath and there's a leak, now in dealer for warranty fix, got a brand new evoque as a courtesy, not a fan! ____________________
