![]() | Home > Faults & Fixes > Burning Smell from Rear offside |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942 ![]() ![]() ![]() |
Mate your post is confusing. In the heading you say offside and in the the post you say near side. It could be the EPB, do a search, lots of information on it here. |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Mine did this and it was the rear caliper sticking. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
Most likely the EPB - when in low range, it is applied with additional force, so could explain the results you saw. |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi , had this on mine and it was the shoes in one of the rear hubs sticking on, Green Flag recovery off the M Way, EPB in effect as i have a bad habbit of just putting it into P instead of using the park brake |
