Home > Wheels & Tyres > Advice on these wheels
J2D
Someone I know is selling a set of 22" wheels that she took off her RRS before selling it, no tyres.
She thinks the wheels are Hawkes, but thats all she can tell me
Pictures below
I'm interested in buying them off her, but I haven't got a clue if that are suitable. after some advice
Can anyone tell from the pictures what wheels they are?
When I look at them, how can I tell if they are the right size (22"), depth and offset?
Post #478224 Thu Oct 29 2015 11:52pm
jasons
2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
All the wheel details including offset will be stamped/cast on the inside of the rim.
J 2012 RRS HSE. Firenze Red.
Post #478236 Fri Oct 30 2015 8:06am
J2D
Thanks J,
What is the ideal width and offset for the RRS of a 22" wheel?
When looking at them, obviously I will be looking for signs of damage, but will it be obvious if they are buckled? or is it a case of not finding that out until i get them balanced with tyres?
For the tyres im looking for 285/35/22, been told Toyo Proxes are best?
Been looking on Blackcircles.com
Toyo Proxes S/T 285/35 R22 W (106) XL are 149.50 and have a rating of E-E-72
Whereas the
Pirelli Scorpion Zero Asimmetrico 285/35 R22 (106) XL are 158.12 and have a better rating of C-B-73
Are the Pirellis worth the 40? The ratings would indicate yes
I have also tried mytyres.com, any other good sites to try?
Post #478390 Sun Nov 01 2015 10:24am
Tyrefitter
I've got 22" Hawkes on mine & I have the pirellis.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #478404 Sun Nov 01 2015 3:37pm
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
J2D, have a look at 4x4tyres.co.uk, the tyres you looked at are 138.60 and 154.60 respectively.
PS I am not affiliated to this company but noticed their lower prices when browsing the web for tyres!
Post #478410 Sun Nov 01 2015 5:00pm
J2D
Had a look at these wheels today, had the following stamped on the inside;
22x10J HS227
ET 30
5 x 112 675KG
5 X 114.3 690KG
5 X 130 735KG
From the above, are these suitable for a RRS???
Post #478880 Thu Nov 05 2015 12:14am
Alex C
2008 Range Rover Sport TDV8 HSE Java Black
Am running toyo proxes on my 22s and they have been amazing. 22k miles done and still stacks of tread, great in wet or dry and very quiet.
Considering the weight of the car the confidence they give is superb, especially under breaking.
Really expected them to wear quickly but they have been very good.
Always found pirrelli to wear very quickly on previous cars so went with Toyo instead - certainly pleased with my decision. Smile
Hope that helps. TDV8 Java Black, Overfinch 22s
Post #478881 Thu Nov 05 2015 12:51am
Farmer Chalk
Not wishing to be a fly in your ointment but the most important figures on those rims related to the load rating of those wheels.... 675kg seems to be very light....
Not sure but it depends what RRS you are running....if you're running the original I seem to remember they need a load rating of at least 900kg each....
Might be taking rubbish this early in the morning but I would definately check....
When I was looking for new wheels for my D4 most aftermarket wheels fell woefully short and I ended up buying original JLR wheels....
Post #478882 Thu Nov 05 2015 8:23am
Buckster
+1 for the above, 900kg on genuine RR Sport alloys Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #478883 Thu Nov 05 2015 8:42am
Farmer Chalk
Thanks Buckster...it's not me going mad then....with a wheel load so light on such a heavy car will lead to a propensity to a minimum of easily buckled rims to a worst case scenario of wheel collapse... Shocked
So at the very least I'd be checking the rims to ensure they are at least still circular! Very Happy
Post #478886 Thu Nov 05 2015 8:56am
J2D
Not at all mate, I appreciate your input. Did think that seemed way too low!
I have a 2011 RRS, would 815kg be too low?
John
Post #479117 Sun Nov 08 2015 11:06am
Farmer Chalk
I'm sure the original wheels you were looking at are fine but it really depends on your usage and loading... If you loaded up and mud plugging or moreover if your missus has a tendency to bounce the car up and down kerbs that it where you'll have your issue... Lots of these type of wheels turn up on EBay and the like after the owner tries to put new tyres on them and realises they are oval.... They should be scrapped but people try their luck and pass them on to unsuspecting buyers who think they are getting a bargain!
I've also seen people try to bash them back into shape (and succeed ) with a rubber mallet!
I was looking for a set from my D4 and frustratingly couldn't find anything that was close to the load rating required other than the standard original wheels!
I'm afraid I don't know the RRS rating but you can't be far off....
Anyone know? Very Happy
Post #479120 Sun Nov 08 2015 12:05pm
I have a Genuine L/R 21" Rim in the garage and the Load Rating is 950Kg's. Borbet rim made in Germany but I think the latest rims are now made in Taiwan but would assume the load rating will be the same.
Post #479122 Sun Nov 08 2015 12:27pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Well I have a set of genuine LR L405 21" wheels with tyres if you are interested. These have a load rating of 950kg. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #479123 Sun Nov 08 2015 12:35pm
Tim in Scotland
Duckworths also have another set of 21" SVR wheels with M&S tyres on them for sale in the for sale section, they will also fit and meet the load rating and the speed rating is higher than any standard RRS will need. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #479127 Sun Nov 08 2015 2:08pm
