Home > Technical > RRS tdv8 won't turn over after holiday. New battery fitted.
Spud88
Hi All, need some help! My sport tdv8 won't turn over after coming back from holiday. When I first tried to start it it turned over but the battery died before it started. I charged the battery overnight tried again and nothing. I then bought a new battery to try but still nothing not even a click from the starter. I checked the relays and the one under the glovebox clicks when I turn the key to position 3 and the one in the engine bay clicks when ignition turned on. I read that there is a common problem with the starter motors on these so I decided to change the starter but still nothing. Does anyone have any idea what could be wrong?
Thanks
Luke
Post #476918 Sun Oct 18 2015 4:14pm
DrRob
Have you had the codes read? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #476919 Sun Oct 18 2015 4:17pm
Spud88
I have a code reader that I use with my phone which isn't very good and I was getting a fault code for vehicle speed sensor that was it. But there could be other codes that my phone doesn't show.
Post #476920 Sun Oct 18 2015 4:31pm
smiler148
Hi mate.
This is a fairly common issue with these things. Have you tried with a jump pack or jumping it off another car? Even if the battery is slightly flat or week can cause issues with starting and through up all sorts of issues.
There was also an issue with a bad earth to the engines on some models. It may be worth placing a jump lead from the battery negative terminal to the engine and see if this works.
Failing that then you will need to check your starter solenoid is getting power and switching correctly.
Hope that helps you.
Post #478202 Thu Oct 29 2015 6:33pm
