Home > Technical > Vibration through car at 60 plus
vam17hel
Has any one had this problem it drives fine till i reach about 60 then i start getting a vibration through the car ,i carries on right up past 75. Ive had all the wheels balanced and new front tyres fitted still there it feels like a transmission thing, i had a new rear propshaft fitted last year and i don't think it was there before but not sure.Are these cars prone to propshaft/driveshaft problems or is this normal,i feel it's coming from the front .Any ideas anyone Confused
Post #474343 Sat Sep 26 2015 6:46pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
I would check the U/J's on the propshaft as it should no vibrate at any speed. You wont need a propshaft but may need U/J's for them.
Also check track rod ends and drive line bushes. Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #474344 Sat Sep 26 2015 6:58pm
vam17hel
ok will do thanks ,i'll check front prop as rear is new and i've just had two new lower arms fitted .do they suffer with front drive shaft problems as i cv joints ??
Post #474347 Sat Sep 26 2015 7:07pm
Frax
I have never had a problem with them and use to have a 2.7.
Others may have but I will let them answer. Lot of Landcruisers now sold
Defender 300tdi 90
Post #474349 Sat Sep 26 2015 7:18pm
vam17hel
Ok thanks Frax Thumbs Up
Post #474353 Sat Sep 26 2015 7:33pm
BKHK
My 2008 (long gone now) had a rear diff replaced for this problem.
Post #474404 Sat Sep 26 2015 11:56pm
Lost for Words
Was it a complete, new rear prop that was fitted? Visiting from DISCO3.CO.UK
Post #474425 Sun Sep 27 2015 8:56am
vam17hel
Yes the centre bearing had collapsed and the people i use would only fit a complete one and they will only use genuine L/R parts i starting to wonder if the front prop is going, did forget to say it is running 22"stormer wheels and they are genuine ones not patterns.I dont thing its the gearbox as all is working fine in auto and sport mode Confused
Post #474499 Sun Sep 27 2015 7:17pm
vam17hel
Also wondered about diffs but cornering makes no difference it the same on sweeping bend and straight lines
Post #474500 Sun Sep 27 2015 7:21pm
