![]() | Home > Technical > Cleaning air filter tdv8 |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4517 ![]() ![]() ![]() |
A new, OEM filter costs less than £10. Please don't clean it, just replace it |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 ![]() ![]() ![]() |
Thanks mate - much appreciated |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
Mikey, how exactly does it help? Just replaced mine but interested in its function, especially in what it prevents. cheers. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
It stops bits of rubbish etc getting into the engine, meaning just air and cleans that by holding any bigger particles (sorry for the basic explanation). Any bits of debris getting through could damage the engine/turbos.
Maybe someone knows or has the same issue. I have a tdv8. Drives beautifully, pulls great once warm and no other issues apart from this whine. Cruising, nothing. The slightest push on the accelerator, then a whine ESP above 50/60. Really can't work it out. Filter is fine, and other bits seem ok. Was serviced 3 months ago, and since then has been into an independent who says it seems fine! You can hear above the radio though.
I had the same problem 2 years back and it was the front offside wheel bearing. replaced it and hey presto, beautiful ride. jack the wheels up and see if you have any play in them. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Just on acceleration? I'll try that. Doesn't fell like a car with a huge problem.... |
And not on cruise (no accelerator) |
acceleration & cruise and appeared around the 50 mark and above Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Ah, mine only whines when I press the accelerator. Cruising, no noise at All. I'll have a check of some things at the weekend. Cheers, Steve |
Hi, has anyone got any ideas at all as the noise is doing my head in.
