Home > In Car Electronics > Satnav does not locate the car properly
TheWojtek
I believe the system uses both the GPS and wheel sensors, which explains why there is the red line across the GPS icon but the screen somehow shows the proper position for a couple of hours after recalibration. Eventually it starts showing a different location, some 20 miles away from where I actually am. I've read a new GPS antenna might be a fix, but I didn't find any procedure for satnav diagnostics. Anyone with a similar experience and a solution? TIA. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #466639 Sun Jul 05 2015 9:25pm
Bodsy
Site Sponsor
So do you have an abs problem as well?
It won't recalculate driving routes without abs speed info.
Search for USB GPS for replacement GPS signal info if it is the problem. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #466657 Sun Jul 05 2015 11:30pm
TheWojtek
No, the ABS is all OK (DSC etc as well). I actually didn't put any route into it to calculate, I just use the map view.
I thought the red line across the GPS icon is because it doesn't have a signal?
I don't actually know what would I do with an USB GPS - would it work as a sort of amplifier or external antenna that feeds GPS signal into the system? Regards etc.,
Wojtek
Post #466692 Mon Jul 06 2015 11:26am
Mr Messy
I had this very problem. New gps antenna fitted into the sharks fin fixed it. There is a write up on how to fix it. £8 antenna from eBay, 10 mm spanner and a number 8 torx bit should be all you need.
Post #466706 Mon Jul 06 2015 1:34pm
TheWojtek
Great, I'm going hunting for the antenna then. Thanks. Regards etc.,
Wojtek
Post #466709 Mon Jul 06 2015 1:53pm
Mr Messy
http://www.rrsport.co.uk/forum/topic32826....ps+antenna
Here is the guide, I needed to go and buy the torx bit as 8 is very small and not in my regular toolbox
Post #466710 Mon Jul 06 2015 1:56pm
Mr Messy
http://www.ebay.co.uk/itm/151706252559?_tr...EBIDX%3AIT
Post #466711 Mon Jul 06 2015 2:00pm
TheWojtek
Great, that's some great stuff. Many thanks. Regards etc.,
Wojtek
Post #466714 Mon Jul 06 2015 2:40pm
TheWojtek
Quick update - problem solved with an aftermarket GPS antenna (costs around 6 quid where I live). The actual culprit was a broken cable that fell out the Fakra GPS antenna connector under the headliner. Thanks for all your help and input, much appreciated. Regards etc.,
Wojtek
Post #467920 Sat Jul 18 2015 1:58pm
Mr Messy
Post #467941 Sat Jul 18 2015 6:43pm
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
I done the fix using £6.00 unit. The post showing installation was spot on. only problem I found was being 20 + stone, Thumbs Up Thumbs Up it awkward putting unit back in roof. I think loose about 10 stone if it goes again
Glad you fixed it at no great expense. Thumbs Up Thumbs Up
PANDA
Supporting the London Air Ambulance with my Brothers
Post #467967 Sat Jul 18 2015 9:49pm
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Just to revive this thread out of many.
My GPS antenna has packed up, when i bought my Parrot Mini Asteroid it came with a GPS antenna that plugs into the parrot with a USB connection.
Could i just lop the end off the USB cable and connect it to the FAKRA plug or is it a completely different kettle of fish?
cheers 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #521948 Sun Mar 26 2017 3:56pm
TheWojtek
I'm afraid it's USB for a reason Sad Regards etc.,
Wojtek
Post #521974 Sun Mar 26 2017 9:52pm
Pakolainen
ok, so need to go and find a normal gps antenna.
Post #522019 Mon Mar 27 2017 11:30am
