![]() | Home > Technical > Idle Adjustment TDV8 |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9112 ![]() ![]() ![]() |
Was that on the fuel pump (diesel) or carburettor (petrol) back in the day? Not sure there are any non-electronic adjustments these days. I'd be concerned that a poor idle is a sign of something amiss somewhere, however. 2012 SDV6 - it's missing a couple of cylinders
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 ![]() ![]() ![]() |
Not a poor idle, just a bit low (400rpm ish) |
Ooh, that is a bit low isn't it. Have you checked for any error codes yet? 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4517 ![]() ![]() ![]() |
400rpm is very low. Should be up around 750-800... |
No error codes |
