![]() | Home > Technical > Fault Code B1D21-13 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5136 ![]() ![]() ![]() |
Have fault code B1D21-13 Remote Control Switch - Circuit open. Says No Steering Wheel Remote In-Car Entertainment Switch pack Functionality. Now everything works fine on the steering wheel control, code clears ok. start car drive forward or backwards in straight line no problem and no code but as soon as turn steering wheel code comes back.
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
Does sound like the clockspring is likely but ISTR the loom is quite cheap and it's usually suggested to start with that. Visiting from DISCO3.CO.UK
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 100 ![]() ![]() ![]() |
Col,
Hi,
