Home > Maintenance & Modifications > Black smoke & oil leak 2008 TDV8 RRS
Madasmad
Hi,
I was driving today and noticed much more black smoke than usual coming from my TDV8 RRS. The car then dropped in to limp home mode stating an engine system fault Censored Censored Censored. I stopped and checked under the bonnet and noticed a thin smear of fresh oil over the left side of the front of the top of the fan cover at the front of the engine. I checked the oil and there was plenty and restarted the engine to see if I could see the leak? I couldn't but the engine fault had cleared so I cleaned the cover and continued my journey. About 100 miles later the car dropped in to limp home mode again so I stopped and checked under the bonnet. The oil was back but again only a relatively thin covering. Upon restarting the engine the fault had cleared and I got home
A couple of questions;
1. Could this be the the turbo hoses and if so would they cause the oil leak?
2. If not any ideas would be appreciated?
Thanks What doesn't kill you only makes you stronger!
2008 RRS TDV8 330Bhp 800nm
Post #462376 Tue May 19 2015 9:07pm
Disco_Mikey
Most likely to be a split turbo hose Thumbs Up
Post #462386 Tue May 19 2015 10:12pm
Madasmad
Thanks Mikey,
Is this is what is leaking the oil as well do you think? What doesn't kill you only makes you stronger!
Post #462396 Tue May 19 2015 10:51pm
Madasmad
Yes it is a split turbo hose and both are being replaced tomorrow.
Disco_Mikey you are a legend Thumbs Up Thumbs Up Thumbs Up What doesn't kill you only makes you stronger!
Post #462473 Wed May 20 2015 5:28pm
Disco_Mikey
I've been called worse! Laughing
Glad I could help, and its a nice, cheap repair Thumbs Up
Post #462528 Wed May 20 2015 10:02pm
