![]() | Home > Technical > Sump gasket changed and steering affected |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Changing the sump gasket appears to be an engine out job. That requires the body to be removed which means they've at least disconnected the lower steering column in the process.
Lmp Member Since: 22 Jul 2020 Location: West london Posts: 1 ![]() ![]() ![]() |
Hi, I’ve just purchased a 2006 RRS 2.7 and theres an oil leek. Got a diagnostic done for £68 from clickmechanic and they said it’s the oil sump gasket. He went on to explain that the oil sump gasket needs replacing as a lot of oil is leaking out and he also mentioned it’s worth changing the sump it self due to the age of the vehicle and the sump having “pours” which leaks oil and these are prone to twisting!? ... is this true or is he just saying this for more cash? Labour cost wise it’s the same price quoted for a gasket change at about £177 if I want the sump changed I just pay the extra it costs him to buy from Land Rover itself... so was wondering if anyone whose experienced in this can help. Thank you very much |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
what engine do you have ? |
