Home > Maintenance & Modifications > Rear Suspension
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Rear Suspension
Hi Lads
Looking to do the Rear Top and Bottom wishbone hub bushes, apart from the manual is there a How Too somewhere on the site for doing these Bushes.
Can it be done without disturbing the the Halfshaft ie can the Wishbones be swung one at a time out of the way to change the bushes so that the hub is still held by the other wishbone.
Also can anyone recommend a reasonably priced set of Pullers for carrying out this job that would also work on most of the other bushes etc on the Suspension.
Cheers Jock Confused
Post #462005 Fri May 15 2015 3:06pm
Have you searched on Disco3? They're more in to the DIY oily stuff and the suspension is the same for the D3 and RRS. 2012 SDV6 - it's missing a couple of cylinders
Post #462027 Fri May 15 2015 8:27pm
Bobby
Could these help...?
http://www.rrsport.co.uk/gallery/albums/us...ushing.pdf
Cool Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #462411 Wed May 20 2015 1:54am
gogsy1956
Do a search on Google for laser rear suspension bush tool, this outfit manufacture a puller for removal of the rear bushes,,,,,,, some on ebay also 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #462417 Wed May 20 2015 8:06am
Jock 77
re Suspension Bushes
Thanks lads will look at these bits and pieces, have also started collecting some bits and pieces to try and make my own if all else fails.
Thanks again for all the info.
Jock. Thumbs Up
Post #462518 Wed May 20 2015 9:06pm
Disco_Mikey
I use a set of these: http://www.ebay.co.uk/itm/UNIVERSAL-BEARIN...5af38048b5
Can be found cheaper mind Thumbs Up
Or, you can rent them:
http://www.ebay.co.uk/itm/RENTAL-LAND-RANG...5b064343e1
http://www.ebay.co.uk/itm/RENTAL-LAND-RANG...5b06435419
Post #462519 Wed May 20 2015 9:12pm
Jock 77
Re Suspension Bushes
Cheers Mike
Will have a look over all these ,It wil probably be a month or say before I get round to them,so plenty time to plan ahead.
Cheers Jock Thumbs Up
Btw Had sent you a p.m Bud not sure if you had got it or not .
Post #462520 Wed May 20 2015 9:18pm
