Home > Maintenance & Modifications > Rear Brakes
steverrs
Scotland 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Rear Brakes
Just had another service completed and have been advised the rear brakes are at 4mm. Does anyone know at what point the sensor will put the warning light on ? Or should I just bite the bullet and have these done now ? I only do 7K a year.
Funnily the front tyres are also worn ?
Thanks,
Steve
Post #460740 Wed Apr 29 2015 10:56am
Disco_Mikey
I believe (but stand to.be corrected) That the light comes on at 2mm. However, there are only 2 sensors to monitor 8 brake pads.
If in doubt, have them replaced, to avoid damaging the discs, and costing even more
Post #460784 Wed Apr 29 2015 7:54pm
steverrs
Mikey, Thank you for your as always accurate response. I will probably replace the discs as well as they do seem a bit corroded as the vehicle does sit for long periods. Due back in June so will drop you a PM.
Post #460803 Thu Apr 30 2015 6:34am
