Home > Technical > Error code P140A, EGR valves ?
paul2415
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I have a engine management light on,the code reader shows an error of P140A, I have been told that this relates to the EGR valves?, my code reader don't specify which one though,i can clear the code and all is well for a couple of day then comes back on,I have a 2007 sport, someone told me to use EGR cleaner on them and rev engine to 3000rpm to clean them ?, how and where would I use the spray cleaner to do this ? I know where the valves are so do I remove a pipe etc to spray into ? as I have been quoted £700 to replace both by a local 4x4 garage or less if only one is required.I have no loss of performance or black smoke etc so I guess the valve is sticking,how easily is it for me to change these ? I am technically minded so don't mind as long as access is ok , thanks for your hely with this guys,thanks.
Post #460576 Mon Apr 27 2015 11:55am
Lost for Words
P140A is the left hand bank. Wink
Forget the EGR cleaner, it's a lost cause.
Blank the EGRs and get a remap to remove the EGR function from the software. Then no more filth going through the engine and better MPG. Smile
Thumbs Up Visiting from DISCO3.CO.UK
Post #460588 Mon Apr 27 2015 1:20pm
paul2415
Ok thanks for the reply,i was told that blanking the egr valves lead to early turbo failure ?,not sure if this is true,thanks.
Post #460601 Mon Apr 27 2015 5:49pm
Disco_Mikey
If that were true, there are thousands and thousands of RRS/D3's just waiting to blow up Laughing
My EGRs were blanked nearly 40k miles ago, and quite a few of them have been HARD miles with its remap. No issues at all Thumbs Up
Post #460605 Mon Apr 27 2015 6:55pm
paul2415
Ok thanks Disco_Mickey, sounds like I am going to go the blanking route,could you recommend someone or somewhere near Essex that I could get the re map done and approx. how much I would expect to pay,thanks for your help.
Post #460606 Mon Apr 27 2015 7:01pm
