Home > General (L494) > Wheel choices
Fletcher
Blimey I never expected that , I stand corrected . Thumbs Up
Post #460533 Sun Apr 26 2015 8:31pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
I don't know of any case, but it would be interesting to see what would happen, for instance, if the steering motor packed up: JLR's warrantors may claim it was due to the wheels, whereas the wheel supplier's warrantors (be them Overfinch or whoever) would only cover the wheels.
Post #460541 Sun Apr 26 2015 9:07pm
chemistry guy
Belgium
Solihull1 wrote:
When changing sizes even with the OEM wheels I think you need to ensure that the dealer changes the settings on the tyre pressure monitoring system too... Particularly if going from a 21"to 22"" wheel..
Indeed correct Solihull1 !
We have just been to the wheel shop, so this is how it was done:
Our new wheels have there own set of TPMS sensors. Uninstalling and installing them on new wheels has a it's
risks. f.e. leaking seals or breaking the sensor.
It is extremely important sensors are the right manufacturer because the L494 TPMS system will not accept every sensor!
Safest way is ordering them on your VIN.
After installation of tyres and sensors the wheels are put into a water bath to check for leaks and afterwards installed on the car.
After detecting all the sensors individually, including the full size spare wheel, with the TPMS reset tool, the tool is connected to the OBD connector and stored in your car. This complete procedure took approx. 8 minutes.
Installing the wrong sensors results in a system fault and no read out of the pressure in the maintenance menu.
With an incorrect new installation this will occur after a short drive.
Greetings,
CG
This a picture of the oem sensors in my RRS 2014.5:
 MY2015 RRS SDV6 Autobiography Dynamic, Corris Grey, Santorini Black Roof, Ebony/Pimento interior, 22 inch Hawke Chayton
Post #460553 Mon Apr 27 2015 5:08am
AB DYN
Andorra
Hi Chemistry Guy
I just ordered a second set of 21" wheels (same size). Can you let me know if I need another set TMPS sensors ?
As I am in Belgium currently - near Hasselt- where should I go ?
Thx. SDV8 AB Dynamic Mariana Black
Post #473747 Mon Sep 21 2015 4:12pm
chemistry guy
Belgium
Hello AB DYN,
If you keep the same size it will not be an issue.
But transferring the TPMS sensors to other wheels (alloys) is always a risk.
Leaks and breaking of the sensor is possible.
Keep in mind the tyres and wheels are your only connection to the ground... and assure your safety.
Donckers in Antwerp (Schoten) has the correct price and knowledge to give you an excellent service. They did my Hawke
Chayton Wheels.
Greetings,
CG MY2015 RRS SDV6 Autobiography Dynamic, Corris Grey, Santorini Black Roof, Ebony/Pimento interior, 22 inch Hawke Chayton
Post #473750 Mon Sep 21 2015 4:53pm
Bobajobbob
Quote:
They make it look like a Hot Wheels car!
Post #473827 Mon Sep 21 2015 10:40pm
