![]() | Home > General (L494) > Ok she's arrived..... |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 325 ![]() ![]() |
I see your points, but I think you just need to get a bit more used to the car.
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1690 ![]() ![]() ![]() |
Are the dipping mirrors extra? Try putting the car in reverse, the adjust the mirrors as you would like, then select drive.
mecxic Member Since: 19 Jan 2015 Location: Stavanger Posts: 7 ![]() ![]() |
I'll persevere a bit longer, as you suggest - there is no alternative, except a Posseur's Porsche - and I don't want to go down that road. What a way to blow £130k however. Let's put it down to First Rate Marketting by L-R UK. |
OK so the Norway spec might be different, but check in the Vehicle set-up menu in the dash menu to see if reverse dipping wing mirrors have been checked/ enabled by the dealership, you can do it yourself if they are not. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Willdo Tim - thanks for reply ...... I couldn't see any option relating to this in the dash menu on a recent search however: it's an HSE with all the bells & whistles ticked at purchase. Collared the dealer recently - he thought it could be on the remote lock package - which is the one I didn't choose (due to a warning about it now being easily cracked via kerbside laptop scanner jockeys) ! Too much background research can sometimes backfire on you, it would seem |
if you have the seat memory, you have the mirror function, if not (as myself) then you dont.
Renaco, agree entirely with your final comment - I have returned to RRS ownership with a car that has only Gangsta glass and 22" Wheels as options from an Evoque that had every electronic/ electrical extra fitted. I don't miss any of the toys from the Evoque aprt from two things - the heated steering wheel (which I will have fitted to the RRS before next winter!) and Road Sign Recognition. The car is excellent even without all the fancy toys. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
