Home > General (L494) > Handbrake
plasterman
Handbrake
Picked up the new HSE Range Rover Sport two weeks ago after three and a half years in the Evoque.When you selected park on the gearbox it put the handbrake automatically on for you,but this new car you have to put it on manually when you select park.
Does everybody else have the same on their vehicle? 2007 HSE in black with 22 inch id ones with privacy glass.
Gone BMW 530d Missed
Gone Porsche Cayenne Goodbye and Good Ridance
Gone BMW X5D
Post #459736 Sun Apr 19 2015 11:19am
Tim in Scotland
Yes I too have come from an Evvoque in the last 3 weeks and find the same annoying "feature" on the RRS2, my previous RRS's both applied the EPB automatically too. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #459740 Sun Apr 19 2015 11:28am
Bodsy
Site Sponsor
Maybe it's a setting that could be changed in the car configuration. Interesting anyway. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #459782 Sun Apr 19 2015 5:49pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
I never use it either.
Post #459832 Mon Apr 20 2015 9:40am
plasterman
We park on an incline on the drive so it gives you a bit of a shock when it suddenly lurches forward and you find yourself suddenly jamming the foot brake on in a panic.
I dont every remember a car which rolls like this before locking itself in park. 2007 HSE in black with 22 inch id ones with privacy glass.
Gone BMW X5D
Post #459916 Mon Apr 20 2015 8:41pm
philmw
Putting the SVR in park is one thing I haven't got used to yet. I'm used to the usual PRND selector. None of this pressing buttons 'n' stuff.
Post #459921 Mon Apr 20 2015 9:01pm
plasterman
Yes takes some getting used to pressing the button for park pushed the stick forward to get park first night got reverse instead.
If you just turn the engine off it will put itself in park too. 2007 HSE in black with 22 inch id ones with privacy glass.
Gone BMW X5D
Post #459922 Mon Apr 20 2015 9:08pm
philmw
It will. After 10 minutes.
Post #459924 Mon Apr 20 2015 9:20pm
Mark_N
Yes, it's slightly counter-intuitive to push the lever forwards to go back and pull it back to go forwards....
I do use the handbrake when parking on a slope. Otherwise, the drivetrain is stressed and the weight of the car carried on the automatic parking mechanism. I had it fail in a Mercedes SL600 once...
Incidentally, have you noticed if you push the lever across to the left to put it in sport mode and then switch off the engine without engaging park, that the lever pops across to the right by itself while also selecting park. Mark
SVR in Estoril Blue Thumbs Up
Post #459925 Mon Apr 20 2015 9:26pm
philmw
Sport mode. In an SVR? Driving Miss Daisy me.
Post #459927 Mon Apr 20 2015 9:41pm
Tim in Scotland
Two other things I have found with the gearbox/ shift:
a) If I stop and switch off without pressing the P button the engine will not stop and I get a warning on the info screen to the effect that I should engage P
b) As somebody who gets steam up when stopped behind a car where the driver is stopped and standing on the footbrake (ie legally not "stopped" as the parking brake isn't on) illuminating the high level brake light right in my face I found with my 9 speed Evoque, when using the Eco Stop/Start, once the engine has stopped automatically if you move the selector to Neutral and apply the parking brake, remove foot from the footbrake (normally this would rerstart the engine) and the engine will remain stopped, high level brake lights go out too, saves some wear on the brake pads too. I have found this also works in my new RRS. When I first expeirenced the Eco Stop/Start I didn't think I could live with it and would switch it off, but now I am used to it I never switch it off as it works so well. The only issue with using the above in the RRS is that sometimes I don't press the detent switch at the back of the gear stick hard enough and the gearbox then won't shift to Drive ready to restart the engine................ Even in the "parked on EPB" mode, if the BMS senses that battery charge is dropping or load is too high, the engine will restart automatically to reduce the electrical load. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #459964 Tue Apr 21 2015 9:10am
Renaco
Re: Handbrake
just coming back on this. Yes, it dosent put the handbrake automatically, but it selects the park block "P" from the gear automatically.
I prefere this, as I dont use the handbrake (99%,only in the mountains), as the parked car has in "P" 5cm movement, what safed me often regarding parking damages on the bumpers.
Post #459982 Tue Apr 21 2015 12:27pm
