Home > Faults & Fixes > Total electrical fail after hitting a bump!
alex_b
United Kingdom 2005 Range Rover Sport TDV6 SE Santorini Black
I have a 2005 RRS 2.7 TDV6 with 60k. We have had electrical problems over the last 12 months (alternator has been checked, ECU has been dried out as was completely waterlogged).
Today had a 'new' one - when hitting a bump in the road the whole vehicle shut down - electrics/steering/engine. On stopping and restarting all seems fine again - until the next pot hole!
Has anyone had anything similar?
Post #456252 Tue Mar 17 2015 9:44pm
Sounds like the vehicle thinks it's crashing. I'd have thought that a loose connection wouldn't reset without physical intervention. 2012 SDV6 - it's missing a couple of cylinders
Post #456274 Tue Mar 17 2015 11:48pm
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
check the battery terminals, i had this on a car i owned many years ago
Post #456281 Wed Mar 18 2015 1:48am
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
Sometimes my radio goes off for a second when I hit bumps,
that's annoying.Wouldn't know where to start trying to find out why.
Supporting the London Air Ambulance with my Brothers
Post #456303 Wed Mar 18 2015 9:56am
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
I agree with Monty- I had the very same thing and one of my terminals was loose. Especially if fiddling about with the battery has happened.
Post #456530 Fri Mar 20 2015 4:10pm
frustrated
2009 Range Rover Sport TDV8 HST Zermatt Silver
Hello Alex. did you manage to source the cause of your engine failure. same thing happened to me 5 times this weekend
each occasion I was travelling at 70 hit bump on the carriageway and dash went out, lost engine and had to cruise to a standstill luckily each time we were on a relatively straight road. Started after each time, only thing that came on was parking brake light (something I never use due to previous issues). any insight would be greatly appreciated.
Post #464632 Mon Jun 15 2015 2:52pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
If ECU was waterlogged - chances are there are other electrical issues caused by this sort of damage. Could be loose or corroded connection that shorts out when jolted anywhere in your system. I'd certainly start with battery and battery cables as well as ground straps (chassis) and alternator connections. Look for loose or corroded wires. But this may be hard to find and need I indie with electrical expertise to start measuring resistance on your wiring loom etc.
Good luck
Post #464636 Mon Jun 15 2015 3:05pm
frustrated
Thanks, battery checked ok, will work backwards from there. LR guy seems to think it is something behind the dashboard.
Will post result as soon as poss.
Post #464757 Tue Jun 16 2015 9:19am
