Home > General > Purchasing a "high" mileage RRS
d15
2008 HST in grey with 135k miles on the clock, am I just asking for problems? What would you guys think this is worth?
Post #455998 Mon Mar 16 2015 12:16am
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
Link to the ad?
Post #456000 Mon Mar 16 2015 12:58am
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Check the service history
If gearbox and all diff , t/c fluids were changed , and control arms, sway bar links, tie rod ends etc. were replaced, wheel bearings, air compressor, air springs etc. you should be able to run to 200K+ on engine and transmission. But if those parts (plus probably a few others) were not taken care of already - budget for replacement bills coming soon - could get quite expensive.
Post #456003 Mon Mar 16 2015 4:10am
Tim in Scotland
Check it is a genuine HST! There were two versions - factory order and dealer build from a kit BUT there are also lots of 2.7SE's dressed up with body kits bought from e-Bay dealers. It's a 2008MY car so also check it is not a "Stormer" S based special edition and was missing everything from the real HST except the body kit, leather upholstry and 20" Stormer alloys - ie it was the then base model with fancy clothes!
Value - nothing more than the base car it was based on - it could be a 2.7HSE, a TDV8 HSE or a 4.2S/C HSE
I have the original sales literature for them if you want to PM me an email address and I'll scan the pages for you. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #456030 Mon Mar 16 2015 10:25am
Agreed. A real HST should, I believe, have the rear e-diff. If that's missing then it's a "dress up" car. 2012 SDV6 - it's missing a couple of cylinders
Post #456032 Mon Mar 16 2015 10:39am
Tim in Scotland
I've just been looking through the original sales literature for 2006-2009 and the HST was only available with either the TDv8 or 4.2S/C motors, a TDv6 version was available with a dealer fitted body kit and exhaust system that made the car look like an HST but was marketed as the Stormer pack, this later became a special factory build limited edition car based on the S version of the RRS. Both the TDv8 and S/C HST's had the e-diff and adaptive cruise as standard fit equipment too.
So if your "HST" doesn't have the TDv8 or 4.2S/C engines or ACC and an e-Diff then it isn't an HST it is a standard RRS with the "Stormer" body kit pack fitted. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #456241 Tue Mar 17 2015 9:00pm
