Home > Faults & Fixes > Power steering fluid leak
Steviesport
Scotland 2008 Range Rover Sport TDV6 HST Stornoway Grey
Hi guys
Seems like power steering fluid deposits on drive , noise when first starts up when turning , took engine tray off to look under & fluid dripping down hoses from near turbo area , any ideas ?
Post #454429 Mon Mar 02 2015 9:40pm
mnk
Hi
Have your steering shaft checked out.
Post #454471 Tue Mar 03 2015 10:27am
Steviesport
Ta for reply ....will it involve taking battery / box out cant see mucb underneath or what else do i need to take out ?
Post #454474 Tue Mar 03 2015 10:44am
mnk
I didn't have any leaks but the steering was really stiff, LR changed the shaft for me and fixed the problem. Spoke to someone else and they said shaft failure is common on this vehicles.
Post #454476 Tue Mar 03 2015 10:53am
Steviesport
I can see it dripping down hose front off turbo area, ive no idea what is in that Position below power steering resiviour hose from it looks kinked going down .nothing but problems after this engine replacement .
Post #454477 Tue Mar 03 2015 11:03am
Vaz
Yeah best thing to do is to get your steering shaft checked out.
Post #454506 Tue Mar 03 2015 2:04pm
Paddi
Assuming it really is a leak from the power steering (should be possible to tell by checking the level in the reservoir):
you need to have the vehicle put up on a lift and the power steering rack and pump and associated pipework inspected for the source of the leak. Don't wait for the power to fail as that can be dangerous.
Problems with the steering column and joints usually involve stiffness, noises or detectable play - not leaks. 2008 MY Java Black TDV8 HSE
Post #454515 Tue Mar 03 2015 2:56pm
Steviesport
All levels seem fine , in with Indy garage twice seems pentland edinburgh made a right arse fitting new engine all hoses required re routing ,still leaking after first attempt just collected car and can't bare to look under car.
Told if it's still leaking its intercooler needing replaced .
Post #456150 Tue Mar 17 2015 12:04am
