![]() | Home > Maintenance & Modifications > Chrome mirror covers removal advice |
jmcvs Member Since: 26 May 2014 Location: Glasgow Posts: 173 ![]() ![]() ![]() |
They are usually held on by double sided tape, so if you use a heat gun and heat the chrome part it should hopefully pull away and you can clean up any residue with brake cleaner or similar |
zaphod Member Since: 16 Jan 2015 Location: UK Posts: 290 ![]() ![]() ![]() |
Thanks, sounds simple enough (famous last words) - will borrow the wife's hairdryer at the weekend and give that a go!
Im in the process of removing my chrome mirror covers and have purchased a full cover already painted in my colour which you then stick over the whole of the back of the mirror. 2006 4.2 Supercharged Buckingham blue
Have you successfully removed one yet then or am I your guinea pig |
There shouldn't be any probs removing them |
Yeah I've bought a few things off them and had no problems. Got the colour coded washer jet covers and whilst they were spot on quality wise, the paint wasn't a 100% match for mine. Close enough to not be that noticeable but enough to irk me a bit. Could just be because of the age of the paint on my car versus fresh paint on the covers?
Received the body colour mirror covers today and they look very good, hopefully put them on either today or tomorrow. Will take pics when done. 2006 4.2 Supercharged Buckingham blue
Great stuff - look forward to seeing them! |
Done the covers tonight, to remove the old covers, heat up with heat gun, hold the mirror and pull the cover off, make sure to clean the mirror before fitting the new covers which fitted spot on.
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
Very nice |
That's definitely a big improvement - and has helped me make my mind up for sure now. My chrome mirrors have to go and I'm getting some body coloured replacements |
They do look a lot cleaner although the pics don't show how good they really look |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
Definitely better without them |
Ordered mine now... will post pics once fitted although may be a while given current lousy weather. Don't have the luxury of a massive workshop to do my install |
