Home > Technical > Brake Judder |
One side worn is probably a sticky caliper. Wear on the disk for front is 30mm new and 27mm needs replacement. Would always replace pads in axle sets. Bodsys Brake Bible
Sun Feb 22 2015 3:57pm |
Tony666 Member Since: 27 Jul 2011 Location: Barry Posts: 170 |
Cheers Bodsy, I'm happy to replace both sets of pads, (I believe they usually come as an axle set anyway), but what about the discs....if there is still plenty of life on one side but the other not so could I replace just 1? Probably about £40 saving so not a lot, but if it doesn't need it..... |
Sun Feb 22 2015 4:01pm |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 |
I personally would change both the discs, then I know that everything required to bring my 2.5 ton beast to a sudden stop when I need it to, is all working and in good order.
Sun Feb 22 2015 4:45pm |
This might seem an obvious comment but don't forget to investigate and fix the sticky caliper. At least strip and clean the sticky one and preferably both sides. If there is an overhaul kit available change the seals and pistons.
Sun Feb 22 2015 6:09pm |
Personally I'd be changing both if you think one is worn more than the other.
Sun Feb 22 2015 6:23pm |
Thanks for the advice guys, I'll look into the caliper, and maybe replace the break fluid... |
Sun Feb 22 2015 11:41pm |
