![]() | Home > Faults & Fixes > Car won't move! |
I'd check the gear linkage first. Could be a £20 fix.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4518 ![]() ![]() ![]() |
Gearbox linkage is first suspect. Very common for seizing up, and causing it to jump out of gear.
RA04SCO Member Since: 20 Feb 2015 Location: Glasgow Posts: 5 ![]() |
I've had a look underneath the car this morning, we selected gear while I looked underneath & it looked like it was selecting normally, the linkage itself looked ok, I'm not a mechanic so can't be 100% sure but they both look fine.
Went to a customers car recently, where the front driveshaft had popped out of the diff, giving him no drive |
Funny you should mention the suspension work, I had just collected the car from the garage when this all happened & it had just been in getting new brakes, new rear tiebar, CV boots and park brake, the garage had just told me that they had taken the rear driveshaft out.
I put it in rock crawl and still nothing, it's just moving slightly forward in drive then slightly backwards in reverse so it's selecting gears fine etc, there's nothin on the dashboard about any faults so I'm hoping it's nothing to major. |
Thanks everyone for your input, had the car recovered to a trustworthy garage who found the problem to be a damaged Nearside rear driveshaft, he asked who had done the previous work as he said they must have saw this as they had it out to carry out repairs and have just refitted the damaged part. This has made me so angry as I have just spent a lot of money with this garage putting faults right that I found myself and asked them to check it over and for them to refit a part that was visibly damaged has got my blood boiling. |
4on4off Member Since: 19 Jun 2015 Location: Perth Posts: 7 ![]() ![]() |
I had a similar problem. Both lower arms replaced and about 20 miles after no drive. had it recovered to the same garage after I had looked at the passenger side driveshaft that had become dislodged. Why would they try to tell me that a bracket had broken and caused this fault. Thoughts!!! |
Trying to cover their own back ends |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2015 ![]() ![]() |
If you live in Glasgow then I'd use Disco_mikey from now on |
We need one in Hampshire |
Dr Rob
Yep, know of them. I buy bits for my 1993 Rangie from them. Enthusiasts, yes!
