Home > Technical > engine management system ?? |
sportman Member Since: 25 Jul 2005 Location: UAE Posts: 550 |
engine management system what it do? any clue? |
Wed Sep 27 2006 10:36am |
I heard that it will adapt the drivers still but is it memorize all the movement of a drive |
Wed Sep 27 2006 10:46am |
LRtuning Member Since: 26 Jul 2005 Location: London and Melbourne Posts: 403 |
Basically, once it has recorded your driving style over a period of time (number of journeys, engine revs, throttle demand etc) it will then try to anticipate your driving style.
Wed Sep 27 2006 11:24am |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 |
HOw does it react if there are two drivers? Does it look for the seat memory setting or is it only able to pull from one set of parameters...Everyone in my house uses my Amazon profile (after all, I pay the bills) which ends up with some pretty schizophrenic recommendations. I would suspect the EMS would do the same unless it is linked to seat memory settings. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Wed Sep 27 2006 11:27am |
I'ts actually the gearbox ecu that adapts to your driving style....so in effect...the 'harder' you drive the quicker the gearbox will respond in order to meet your demands. |
Wed Sep 27 2006 11:37am |
