Home > Maintenance & Modifications > Help with light bulb replacment
stebenny
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Could someone please tell me what bulbs i need, I am looking at the Osram night breaker unlimited, I think they are H7 if so how many do i need and which bulbs do i need to replace the side and reversing light
Thanks Steve
Post #449042 Mon Jan 19 2015 10:22pm
H7 is the headlight main beam fill-in bulb. Sidelights are 501 W5W. Reversing lights are 382 I think. You need two of each.
Look at Advanced Factors in the sponsors area Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #449052 Mon Jan 19 2015 11:11pm
stebenny
Thanks for the reply, so do I need 4 H7 bulbs 2 for the headlights and 2 for the full beam, Thanks Steve
Post #449082 Tue Jan 20 2015 11:32am
If you have Halogens, yes.
Here's a list of bulbs from the Owners Manual Thumbs Up
 ON THE WAY: BMW F21 M140i
Post #449084 Tue Jan 20 2015 11:42am
flydive
Do not trust the manual on headlight bulbs, check what you actually have. '08 RRS TDV8
Post #449099 Tue Jan 20 2015 1:57pm
stebenny
Thanks, This might sound daft but will mine be halogens i have a 2008 RRs
Post #449124 Tue Jan 20 2015 7:08pm
Techstyles
Belgium 2005 Range Rover Sport TDV6 HSE Maya Gold
Probably a stupid question but can you buy zenon H7 bulbs and replace the H7 Halogens? I dont even know what I have to be honest.
And can anybody recommend a brand/type?
Thanks
Post #452343 Thu Feb 12 2015 4:35pm
Lost for Words
You can fit H7 bulbs that use Xenon gas to produce more light but these are not the same as an HID system which requires ballasts to create a higher voltage etc. An HID system operates by creating an electric arc rather than a filament. There are good HID kits available, and plenty of bad ones, but none are road legal. A decent, well fitted kit should not cause undue glare to drivers but it is still not legal. Thumbs Up Visiting from DISCO3.CO.UK
Post #452354 Thu Feb 12 2015 5:09pm
worth replacing the reversing with LED's from Advanced Factors IMO Thumbs Up ON THE WAY: BMW F21 M140i
Post #452366 Thu Feb 12 2015 6:29pm
Techstyles
Ok but say I have the H7/11 Halogen bulbs, can i then opt to use these xenon bulbs instead?
66240XNB OSRAM XENARC D2S NIGHT BREAKER UNLIMITED
Post #452433 Fri Feb 13 2015 4:26pm
Lost for Words
While, I think, you might be able to get the D2S bulb to fit in an H7 with an adapter, you would have to ensure the arc remains at the focal point of the reflector. The slightest change (even just 1mm) has a dramatic effect on the light output. You would also have to purchase ballasts and wire them in or the bulbs would not function. In short, you could not just replace the H7s with those.
If you don't have the xenon lights, the best bet is just to swap the units. Thumbs Up
If you really want to upgrade your halogen main beam, this is a proper H7 conversion kit containing what you need: http://www.hids4u.co.uk/h7-55w-pro-max-xen...n-kit.html
PS: 15% off with DISCO315 Wink Visiting from DISCO3.CO.UK
Post #452436 Fri Feb 13 2015 5:14pm
Techstyles
Thanks, to be honest I dont even know if I have the xenons but i think i do........lmao is there an easy way to check or do I have to remove the light clusters.
Post #452438 Fri Feb 13 2015 5:19pm
