Home > Technical > FBH remaining on
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
FBH remaining on
Question about the FBH. I've noticed fuel economy decreases a fair bit in Winter, and I wondered if the FBH was the culprit. I understand the FBH firing up below 4c, but I assumed that once the engine temp was up the FBH would stop? Yesterday I drove for over 100 miles, temp 2c, but my FBH was still operating at the end of the journey.....surely this is not right?
Post #448990 Mon Jan 19 2015 5:11pm
Russben
Mine does the same. I thought it should have switched itself off once the engine was up to normal temperature. I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #448991 Mon Jan 19 2015 5:17pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hello Tony.
Itīs aboslututely right. Thumbs Up
The FBH:s job is to help Your dieselengine, which is a
not so effective heatingplant, since almost all the energy
in the diesel becomes Torque..
Compared to an Gasoline engine where almost half the energy
becomes heat..
So the FBH assists the engine in maintaining a temperature
at approx 75C, and when the temp is in that region, the FBH
goes into a lower setting, almost "idling", and when needed
it goes "full tilt" again.
So there seems to be nothing wrong with Your FBH, sir.. Thumbs Up
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #448993 Mon Jan 19 2015 5:23pm
Gornal Hills
Does anyone know how economical the FBH really is ?? wouldn't of thought it drank a lot !! Confused 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #449008 Mon Jan 19 2015 6:50pm
Andi
Economy has probably decreased due to the winter diesel. This can make a reasonable difference to your mpg.
Post #449011 Mon Jan 19 2015 7:06pm
Tony666
Thanks very much for the replies, has answered my question and put my mind to rest.
Post #449034 Mon Jan 19 2015 9:04pm
Maxarn58
Hi guys.
At full power (5kW) the FBH consumes 0,6l/h
At partial load, 0,35l/h
Post #449053 Mon Jan 19 2015 11:14pm
gogsy1956
Hi Ufffe
Do you know if the fbh will operate if the car is left unlocked, engine not running and temp below the required 5 deg. It's only that I had issues with mine the other day whereby the battery ran flat overnight after being perfect the day before. I'm sure I heard the fbh running before I tried to start it.
Car had been garaged and unlocked during the night. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #449074 Tue Jan 20 2015 10:15am
The FBH shouldn't run without the engine running unless you have the timed system or something like BAS's remote controller. I would expect the garage would be very unpleasant to walk in to if the FBH had been running for a while.
It's possible your FBH has a fault and the fan is running constantly - it sometimes does run on a bit at shut down to cool the burner unit but not for very long. Pull the FBH's fuse and see what happens to the battery overnight. 2012 SDV6 - it's missing a couple of cylinders
Post #449078 Tue Jan 20 2015 10:30am
gogsy1956
I see, as you said if the fbh had been running there would have been a rather unpleasant smell, but there was definitely something running, it could well have been the fan that you mentioned.
Where exactly is this located, is it part of the heater unit and not something you can actually get your fingers on.
This has only happened the once, al has been okay since the other day.
Cheers 2010 RRS, TDV8
22" overfinch
Post #449083 Tue Jan 20 2015 11:41am
The fan is part of the FBH I think. 2012 SDV6 - it's missing a couple of cylinders
Post #449103 Tue Jan 20 2015 2:35pm
