![]() | Home > General > RRS break fade??? |
Ok, now delete your vin from the post. |
BUT I would go to LR with the po17 recall and explain your symptoms as it is exactly the same issue. I would pressure LR to fix this dangerous and well documented fault F.O.C. At this stage, it probably needs new brake booster and pipe work. Probably also new master cylinder and brake fluid. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
jonesy#93 Member Since: 19 Jan 2015 Location: shropshire Posts: 9 ![]() ![]() |
oh ok cool thanks for that il call them any way to see if they can help me!!! I see your a site sponsor do you deal with rrs as a job?? |
Not the day job, more of a hobby, but I do know a thing or two about these |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4506 ![]() ![]() ![]() |
More than enough to keep you in a day job though |
Every little helps |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
just rang them and asked them to check if my vehicle had had its recall or was it still oustsanding, they said it hadnt been done and they could do it friday free of charge ![]() |
Rang today but has had all recalls done so looks like it's down to roean Tuesday thanks for the help gents |
Your problem is the oil in the servo issue. Personally, I would get LR to inspect it as tbh, many of the recalls weren't inspected properly, they just changed the pipe.
Took rangy into kentdale this morning and they rang me about an hour later saying servo was full off oil so they are fitting a new one. I wonder what the cost would have been |
