Home > Technical > Air con leaking
daxmatt
Air con leaking
As title Sad ,,any common areas i should look for its a supercharged 06
Post #448753 Sat Jan 17 2015 7:17pm
Disco_Mikey
Front condenser. Get it checked with an AC specialist. They inject a UV dye, which flows under a UV light, highlighting any leaks Thumbs Up
EDIT: If it has rear AC, they leak near the rear axle. Cheaper and easier to blank off the rear AC
Post #448755 Sat Jan 17 2015 7:26pm
daxmatt
Thanks mike
will do Very Happy
Post #448756 Sat Jan 17 2015 7:37pm
RRSNUT
2006 Range Rover Sport TDV6 HSE Java Black
Hi,
Sorry for hijacking your post but same issue here.
Getting AC re gassed last week and was informed that I have a leak somewhere. Advised AC specialist to inject UV dye into system to source the leak.
Have checked some reviews of local companies but most are fairly negative.
Does anyone have any experiences of AC specialists in South Wales ? Sheep
Don't want to get turned over as I can see this being a hefty expense if not dealt with correctly. Shocked
Thanks Thumbs Up
RRSNUT Sheep North Wales Land Rover Club Member
RRS 2.7 TDV6 HSE. MY06. JAVA BLACK. FULL BLACK NAPPA
- CLEAR SIDE REPEATERS - SIDE STEPS - PARROT BLUE TOOTH PHONE - GENERAL GRABBER AT's - EGR VALVES REMOVED
Post #464776 Tue Jun 16 2015 1:34pm
UK Guy
England 2013 Range Rover Sport SDV6 Autobiography Santorini Black
On my 06 RRS 2.7 I had an issue after the dealer talked me into an air con service whilst it was in for other work.
Within a week I had no aircon. I took it back and all they wanted to do was charge me for investigation so took it to a LR specialist indi who tracked the fault down to the filler valve (which the dealer disturbed) New Valve fitted and been fine ever since.
Worth a look if you have had any sort of refill. RRS HSE with a few extras & a
2013 RRS Autobiography
Post #464809 Tue Jun 16 2015 6:59pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Stones like to crack the condenser radiator.... 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #464840 Tue Jun 16 2015 10:19pm
