Home > Maintenance & Modifications > Driving & fog light combo
Bodsy
Site Sponsor
Spots can come on with main beam, either with the std kit (and enabling) or by the traditional method of relays from the existing main beam. But best to be able to stop them from coming on if you need to via the switch.
You could put the switch (or use a different switch) somewhere else so you don't cut into the dash area. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #448512 Wed Jan 14 2015 11:31pm
I can enable them with my IID Tool I think. It's the rest of it that looks a bit daunting. Just had a read of some earlier threads - someone mentioned it being a pig of a 6 hour job to install them! That's a pricey proposition (or a fair chunk of a weekend on the driveway).
I might ask a local indie that I'm going to use for servicing from now how much they would charge to do it. That's assuming they've ever done one before, of course. 2012 SDV6 - it's missing a couple of cylinders
Post #448516 Wed Jan 14 2015 11:51pm
Bodsy
Site Sponsor
You should be able to do it with IID. If not, then gap will update it for that function I'm pretty sure.
These are a bit of a pig, but mostly just time consuming. Make sure the cuts are accurate etc. any reasonable auto electrician should be able to do it. Thumbs Up Bodsys Brake Bible
See it HERE
Post #448517 Thu Jan 15 2015 12:10am
